This procedure does not apply to XA1400 Series.
Configure broadcast/unknown unicast and multicast bandwidth limiting to limit the amount of ingress traffic on a port. The switch drops traffic that violates the bandwidth limit.
VSP 8600 Series does not support this feature for unknown unicast traffic.
The following table defines parameters for the rate-limit command.
                                 Variable  |
                                 Value  |
                                 {<1-65535> | <50-65000000>}  |
                                 Specifies the bandwidth limit for broadcast/unknown unicast and multicast traffic, in packets per second (pps). Note:
                            The <50-65000000> range only applies to VSP 8600 Series.  |
                                 port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
                                 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
