Enable jumbo frames to increase the size of Ethernet frames the chassis supports.
Switch:1> enable
Switch:1# configure terminal
Enable jumbo frames to 9600 bytes:
Switch:1#(config)# sys mtu 9600
The following table defines parameters for the sys mtu command.
 Variable  |
 Value  |
 <1522-9600>  |
                             Configures the frame size support for the data path. Possible sizes are 1522, 1950, or 9600 bytes. The default is 1950 bytes.  |
