This procedure only applies to the VSP 7400 Series.
Enable Distributed Virtual Routing (DvR) globally on the node.
Perform this procedure to view the DvR Multi-area SPB backbone entries that the system learns from all Controllers in all DvR domains.
You can view the backbone entries only on a DvR Controller. Viewing backbone entries does not apply to a DvR Leaf node.
  1. In the navigation pane, expand the Configuration > Fabric folders.
  2. Select DVR.
  3. Select the MultiArea Backbone Entries tab.
  4. Optional: Select the Filter button to filter the rows on basis of specific criteria.
MultiArea Backbone Entries Field Descriptions
Use the data in the following table to use the MultiArea Backbone Entries tab.
Name
Description
IpAddrType
Specifies the address type of the DvR backbone host (IPv4 remote ARP).
IpAddr
Specifies the IPv4 address of the DvR backbone host.
L3Isid
Specifies the Layer 3 I-SID of the DvR backbone host.
DomainId
Specifies the domain ID of the DvR backbone host.
EcmpIndex
Specifies the ECMP index of the DvR backbone host.
HostMacAddr
Specifies the MAC address of DvR backbone host.
L2Isid
Specifies the Layer 2 I-SID of the DvR backbone host.
AdvControllerName
Specifies the host name of the advertising Controller.
AdvController
Specifies the host MAC address of the advertising Controller.
NextHopName
Specifies the host name of the next hop Backbone host in the DvR route.
NextHopMac
Specifies the MAC address of the next hop Backbone host in the DvR route.
Area
Specifies the type of area as home or remote.
