After you assign the IP address, you can configure ARP. By default, ARP Response is enabled and Proxy ARP is disabled.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
ARP field descriptions
Use the data in the following table to use the ARP tab fields.
 Name  |
 Description  |
 DoProxy  |
 Configures the system to respond to an ARP request from a locally attached host or end station for a remote destination. The default value is disable.  |
 DoResp  |
 Configures the system to send ARP responses for this IP interface address. The default value is enable.  |
