View and manage general IPv6 information.
Switch:1(config)#show ipv6 interface vlan
                                             Vlan Ipv6 Interface
IFINDX VLAN PHYSICAL          ADMIN   OPER  TYPE  MTU  HOP REACHABLE   RETRANSMIT  MCAST    IPSEC    RPC      RPCMODE
INDX        ADDRESS           STATE   STATE            LMT TIME        TIME        STATUS
2070   22   e4:5d:52:3c:65:02 disable down  ETHER 1500 64  30000       1000        disable  disable  disable  existonly
                               Vlan Ipv6 Address
IPV6 ADDRESS                            VLAN-ID      TYPE    ORIGIN    STATUS
fe80:0:0:0:e65d:52ff:fe3c:6502          V-22         UNICAST LINKLAYER INACCESSIBLE
1 out of 2 Total Num of Interface Entries displayed.
1 out of 2 Total Num of Address Entries displayed.
            Switch:1#show ipv6 interface tunnel
                                  Tunnel Ipv6 Interface - GlobalRouter
IF   Descr         VLAN PHYSICAL          ADMIN   OPER  TYPE  MTU  HOP REACHABLE   RETRANSMIT  MCAST
6656 T-1           0    n/a               enable  down  P2P   1280 64  30000       1000        disable
                              Tunnel Ipv6 Address
IPV6 ADDRESS                            TUNNEL-ID    TYPE    ORIGIN    STATUS
11:0:0:0:0:0:11:11/32                        T-1          UNICAST MANUAL    INACCESSIBLE INF      INF
fe80:0:0:0:0:0:b0b:b0b/64                    T-1          UNICAST LINKLAYER INACCESSIBLE INF      INF
1 out of 5 Total Num of Interface Entries displayed.
2 out of 9 Total Num of Address Entries displayed.
            Switch:1#show ipv6 address interface tunnel 2
                                   Address Information
IPV6 ADDRESS/PREFIX LENGTH                   VID/BID/TID  TYPE    ORIGIN    STATUS
44:211:0:0:0:0:0:2/64                        T-2          UNICAST MANUAL    PREFERRED
fe80:0:0:0:0:0:d301:3702/64                  T-2          UNICAST LINKLAYER PREFERRED
2 out of 407 Total Num of Address Entries displayed.
            Switch:1#show ipv6 address interface vlan 100
                                   Address Information
10:1:50:0:0:0:0:7/64                         V-100        UNICAST MANUAL    PREFERRED
fe80:0:0:0:b2ad:aaff:fe46:f19a/64            V-100        UNICAST LINKLAYER PREFERRED
            Switch:1#show ipv6 forwarding
        Ipv6 forwarding - GlobalRouter : enable
        ecmp                           : disable
        ecmp-max-path                  : 1
            Switch:1#show ipv6 global
                     IPv6 Global Information - GlobalRouter
	forwarding                     : disable
	default-hop-cnt                : 64
	number-of-interfaces           : 1
	icmp-error-interval            : 1000
	icmp-error-quota               : 50
	icmp-unreach-msg               : disable
	icmp-addr-unreach-msg          : enable
	icmp-port-unreach-msg          : enable
	icmp-echo-multicast-request    : enable
	static-route-admin-status      : enable
	alternative-route              : enable
	ecmp                           : disable
	ecmp-max-path                  : 1
	source-route                   : disable
	host-autoconfig                : disable
            Switch:1#show ipv6 nd interface vlan
                                      Vlan Ipv6 Nd - GlobalRouter
IFID VLAN   RTR-ADV MAX-INT MIN-INT LIFETIME MANAG OTHER DAD-NS MTU     HOP
                                             FLAG  CONF                 LIMIT
TIME      TIME
2092  V-44  True    600     200     1800     False False 1      0(d)    64(d)  30000(i)  1000(i)
2081  V-33  True    600     200     1800     False False 1      0(d)    64(d)  30000(i)  1000(i)
Note:  (s) = Set, (d) = Default, (i) = inherit.
2 out of 2 Total Num of Ipv6 ND Entries displayed.
            Switch:1#show ipv6 nd interface mgmtEthernet mgmt
                                             Mgmt Ipv6 Nd
IFID MGMT-IF RTR-ADV MAX-INT MIN-INT LIFETIME MANAG OTHER DAD-NS MTU     HOP    REACHABLE RETRANSMIT
                                             FLAG  CONF                 LIMIT  TIME      TIME
64   mgmt   False   600     200     1800     False False 1      0(d)    64(d)  0(d)      0(d)
            Switch:1#show ipv6 nd-prefix interface gigabitethernet
                              Port Ipv6 Nd Prefix
INTF  IPV6                                           BTR   VALID       PREF     EUI
INDEX ADDRESS/PREFIX                                       LIFE        LIFE
344   2011:beef:4004:0:0:0:0:0/64     	               5/25   2592000    604800 1
1 out of 9 Total Num of Ipv6 ND prefix Entries displayed.
            Switch:1#show ipv6 nd-prefix interface vlan
                              Vlan Ipv6 Nd Prefix
INTF  IPV6                                           VLAN  VALID       PREF EUI
INDEX ADDRESS/PREFIX                                 ID    LIFE        LIFE
2148  2011:beef:100:0:0:0:0:0/64                     100   2592000     604800 1
2158  2011:beef:110:0:0:0:0:0/64                     110   2592000     604800 1
2248  2011:beef:200:0:0:0:0:0/64                     200   2592000     604800 1
2258  2011:beef:210:0:0:0:0:0/48                     210   2592000     604800 1
2548  2011:beef:500:0:0:0:0:0/64                     500   2592000     604800 1
2648  2011:beef:600:0:0:0:0:0/64                     600   2592000     604800 1
2948  2011:beef:900:0:0:0:0:0/64                     900   2592000     604800 1
7 out of 9 Total Num of Ipv6 ND prefix Entries displayed.
            Switch:1#show ipv6 nd-prefix vlan 100
                         Nd-Prefix Address Information
Legend: EUI: eui-not-used(1), eui-used-with-ul-complement(2)eui-used-without-ul-complement(3)
            Switch:1#show ipv6 neighbor type 4
                                     Neighbor Information - GlobalRouter
NET ADDRESS/                             IPV6   PHYS               TYPE    STATE      LAST TUNNEL
PHYSICAL ADDRESS                         INTF   INTF                                  UPD
123:0:0:0:0:0:0:123/                     C-1    cpp                LOCAL   REACHABLE  0
    00:00:00:00:00:01
1 out of 1 Total Num of Neighbor Entries displayed.
            Switch:1(config)#show ipv6 neighbor
22:0:0:0:0:0:0:22/                       V-22   1/2                DYNAMIC REACHABLE  570
    84:83:71:49:38:82
22:0:0:0:0:0:0:44/                       V-22   cpp                LOCAL   REACHABLE  523
    d4:ea:0e:c8:8c:81
fe80:0:0:0:8683:71ff:fe49:3882/          V-22   1/2                DYNAMIC DELAY      579
    84:83:71:49:38:82
fe80:0:0:0:d6ea:eff:fec8:8c81/           V-22   cpp                LOCAL   REACHABLE  523
    d4:ea:0e:c8:8c:81
Use the data in the following table to use the show ipv6 commands.
 Variable  |
 Value  |
 address interface ip WORD<0-46>  |
 Specifies the IPv6 address.  |
 neighbor [WORD<0-46>]  |
 Specifies the IPv6 address of the neighbor.  |
                             loopback <1-256>  |
                             Specifies the loopback interface ID value. If you do not specify a value, the output includes all IPv6 loopback interfaces.  |
 {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
 type <1–4>  |
 Specifies the neighbor type as one of the following:
                             tunnel <1–2000>  |
                             Specifies the tunnel ID.  |
 vlan <1-4059>  |
 Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.  |
 vrfWORD<1–16>  |
 Specifies the VRF name.  |
 vrfidsWORD<1–256>  |
 Specifies the VRF ID.  |
