Perform the following procedure to view the number of remaining virtual services resources on the switch.
  1. In the navigation pane, expand the Configuration > Serviceability folders.
  2. Click Virtual Service.
  3. Click the Globals tab.
Use data in the following table to use the Globals tab.
Name
Description
DiskRemain
Shows the remaining disk space available, in Gigabytes (GB).
NumCoresRemain
Shows the remaining number of CPU cores available.
MemSizeRemain
Shows the remaining amount of memory size available, in Megabytes (MB).
CopySourceFile
Specifies the source file to copy. To specify a location, use the format: {VM_NAME_SRC}:{VM_FILE_PATH} or {NOS_FILE_PATH}. For example, figw:/home/rwa/configs/ipsec1.cfg identifies a file located in the VM. /intflash/ipsec1.cfg identifies a file located in the NOS. The valid path for a NOS location can be one of the following:
  • /intflash
  • /extflash
  • /usb
  • /var/lib/insight/packages
CopyDestinationFile
Specifies the destination file to copy. To specify a location, use the format: {VM_NAME_DST}:{VM_FILE_PATH} or {NOS_FILE_PATH}. For example, figw:/home/rwa/configs/ipsec1.cfg identifies a file located in the VM. /intflash/ipsec1.cfg identifies a file located in the NOS. The valid path for a NOS location can be one of the following:
  • /intflash
  • /extflash
  • /usb
CopyAction
Specifies an action to copy a file from source to destination. The switch supports the following action:
  • Copy
  • None
ScalarsName
Specifies the virtual service name. You must specify the virtual service name if you use this tab to change the password or run a command.
ExecuteCommand
Specifies the Virtual Machine (VM) command to run. To include spaces in the syntax, include the text string in quotation marks (").
User
Specifies the virtual service user name. The range is 0-20 characters.
Password
Specifies the virtual service password.
FigwCli
Specifies the command to send to the Fabric IPsec Gateway VM. For more information about Fabric IPsec Gateway commands, see VOSS CLI Commands Reference.
