This procedure does not apply to VSP 8600 Series.
Use this task to configure IPv4 static routes for Management Instances.
For the Management Instance CLIP, you do not need to configure a default or static route. This interface type uses all routing information learned by protocols attached to the VRF. For more information about how to associate a VRF with the CLIP interface, see Configure a Segmented Management Instance.
For the Management Instance OOB and VLAN, you must configure a default or static route to reach the next-hop gateway; no routing protocol information is used to access off-link networks.
You can configure up to 100 IPv4 and IPv6 static routes.
 - Expand Mgmt Instance.
 - Select Mgmt.
 - Select the IpStaticRoute tab.
 - Select Insert.
 - For the Instance, select the type of Management Instance interface.
 - Type the destination IP address and mask.
 - Type the next hop IP address.
 - Type a metric value.
 - Select Insert.
IpStaticRoute Field Descriptions
Use the data in the following table to use the IpStaticRoute tab.
 Name  |
 Description  |
 Instance  |
 Specifies the Management Instance.  |
 DestAddr  |
 Specifies the destination IP address.  |
 DestMask  |
 Specifies the destination mask.  |
 NextHop  |
 Specifies the next hop address for the static route. Use an IP address in the same subnet as the management VLAN IP address.  |
 IntfName  |
 Specifies the Management Instance interface name for the route entry.  |
 Metric  |
 Specifies the static route cost. The default is 200. The management CLIP uses an internal static route with a weight of 100. If you use both CLIP and VLAN and need to force all default traffic out the management VLAN interface, configure a default static route with a weight lower than 100.  |
 State  |
 Shows if the route is active or inactive.  |
