Clear DvR host entries (IPv4 remote host routes) on a Controller. The host entries are learned on the switch either locally on its UNI port or dynamically from other nodes in the DvR domain.
You can clear DvR host entries only on a DvR Controller.
An error message displays if you attempt clearing of host entries on a DvR Leaf node.
Ensure that you enable DvR globally on the node.
 - Click DVR.
 - Click the Clear Host Entries tab.
 - Update the fields as necessary, and then click Apply to save your configuration.
Clear Host Entries field descriptions
Use the data in the following table to use the Clear Host Entries tab.
 Name  |
 Description  |
 ClearAll  |
 Select to clear all DvR host entries.  |
 ClearIpv4  |
 Specifies the IPv4 address of the DvR host entries to clear. The IPv4 address must not be the VLAN IP address on any Controller within the DvR domain.  |
 ClearL2Isid  |
 Specifies the Layer 2 VSN I-SID of the DvR host entries to clear. The range is 0 to 16777215.  |
 ClearL3Isid  |
 Specifies the Layer 3 VSN I-SID of the DvR host entries to clear. The range is 0 to 16777215.  |
