Use this procedure to view FA statistics.
 - Click Fabric Attach.
 - In the content pane, click the Stats tab.
Stats field descriptions
Use the data in the following table to use the Stats tab.
 Name  |
 Description  |
 PortIndex  |
 Specifies the port for which the FA statistics are displayed.  |
 DiscElemReceived  |
 Specifies the number of element discoveries received on the port.  |
 AsgnReceived  |
 Specifies the number of remote assignments received on the port.  |
 AsgnAccepted  |
 Specifies the number of remote assignments accepted on the port.  |
 AsgnRejected  |
 Specifies the number of remote assignments rejected on the port.  |
 AsgnExpired  |
 Specifies the number of remote assignments that have expired, on the port.  |
 AuthFailed  |
 Specifies the number of authentications that have failed on the port.  |
 DiscElemExpired  |
 Specifies the number of discovery elements that have expired on the port.  |
 DiscElemDeleted  |
 Specifies the number of discovery elements that are deleted on the port.  |
 AsgnDeleted  |
 Specifies the number of remote assignments deleted on the port.  |
                             AsgnAuthFailed  |
                             Specifies the number of remote assignment authentications that failed on the port.  |
