Use the following procedure to display the IS-IS interface parameters.
Switch:1# show isis interface
                                ISIS Interfaces
IFIDX    TYPE   LEVEL    OP-STATE    ADM-STATE  ADJ  UP-ADJ  SPBM-L1    OP-SPBM-   ORIGIN   AREA   AREA-NAME
                                                             -METRIC    L1-METRIC
Mlt2     pt-pt  Level 1    UP         UP         1    1       10         10        CONFIG   HOME  area-9.00.02
Port1/21 pt-pt  Level 1    UP         UP         1    1       10         10        CONFIG   HOME  area-9.00.02
                  Switch:1# show isis int-auth home
                              ISIS Interface Auth
IFIDX        AUTH-TYPE   AUTH-KEYID  AUTH-KEY   ORIGIN    AREA   AREA-NAME
Mlt2         none        0                      CONFIG    HOME   area-9.00.02
Port1/21     none        0                      CONFIG    HOME   area-9.00.02
                  Switch:1# show isis int-timers home
                             ISIS Interface Timers
IFIDX        LEVEL      HELLO         HELLO         HELLO   AREA   AREA-NAME
                        INTERVAL      MULTIPLIER    DR
Mlt2         Level 1        9          3             3     HOME    area-9.00.02
Port1/21     Level 1        9          3             3     HOME    area-9.00.02
                  Switch:1# show isis int-ckt-level home
                         ISIS Circuit level parameters
IFIDX           LEVEL          DIS        CKTID      AREA   AREA-NAME
Mlt2            Level 1                    1         HOME    area-9.00.02
Port1/21        Level 1                    2         HOME    area-9.00.02
The following table defines parameters for the show isis interface command.
 Variable  |
 Value  |
                                                 home  |
                                                 Displays the IS-IS interface information that the system configures in the home area.  |
 l1  |
 Displays the interface information for Level 1.  |
                                                 l2  |
                                                 Displays the interface information for Level 2.  |
                                                 l12  |
                                                 Displays the interface information for Level 1 and Level 2.  |
                                                 remote  |
                                                 Displays the IS-IS interface information that the system configures in the remote area.  |
The following table defines parameters for the show isis ini-auth command.
                                                 Variable  |
                                                 Value  |
                                                 home  |
                                                 Displays the IS-IS interface authentication information that the system configures in the home area.  |
                                                 remote  |
                                                 Displays the IS-IS interface authentication information that the system configures in the remote area.  |
The following table defines parameters for the show isis ini-timer command.
                                                 Variable  |
                                                 Value  |
                                                 home  |
                                                 Displays the IS-IS interface timer information that the system configures in the home area.  |
                                                 remote  |
                                                 Displays the IS-IS interface timer information that the system configures in the remote area.  |
The following table defines parameters for the show isis ini-ckt-level command.
                                                 Variable  |
                                                 Value  |
                                                 home  |
                                                 Displays the IS-IS interface circuit level parameters that the system configures in the home area.  |
                                                 remote  |
                                                 Displays the IS-IS interface circuit level parameters that the system configures in the remote area.  |
