Use the server statistics feature to display the number of input and output packets and the number of input and output bytes. Statistics from console ports are available to assist with debugging.
 - Click RADIUS.
 - Click the RADIUS Servers Stats tab.
RADIUS Server Stats Field Descriptions
Use the data in the following table to use the RADIUS Server Stats tab.
 Name  |
 Description  |
 AddressType  |
 Specifies the type of IP address. RADIUS supports IPv4 addresses only.  |
 Address  |
 Shows the IP address of the RADIUS server.  |
 Used by  |
 Identifies the client.  |
 AccessRequests  |
 Shows the number of access-response packets sent to the server; does not include retransmissions.  |
 AccessAccepts  |
 Shows the number of access-accept packets, valid or invalid, received from the server.  |
 AccessRejects  |
 Shows the number of access-reject packets, valid or invalid, received from the server.  |
 BadResponses  |
 Shows the number of invalid access-response packets received from the server.  |
 PendingRequests  |
 Shows the access-request packets sent to the server that have not yet received a response or that have timed out.  |
 ClientRetries  |
 Shows the number of authentication retransmissions to the server.  |
 AcctOnRequests  |
 Shows the number of accounting on requests sent to the server.  |
 AcctOffRequests  |
 Shows the number of accounting off requests sent to the server.  |
 AcctStartRequests  |
 Shows the number of accounting start requests sent to the server.  |
 AcctStopRequests  |
 Shows the number of accounting stop requests sent to the server.  |
 AcctInterimRequests  |
 Number of Accounting Interim requests sent to the server. Important:
 The AcctInterimRequests counter increments only if you select AcctIncludeCli from the RADIUS Global tab.  |
 AcctBadResponses  |
 Shows the number of Invalid responses discarded from the server.  |
 AcctPendingRequests  |
 Shows the number of requests waiting to be sent to the server.  |
 AcctClientRetries  |
 Shows the number of retries made to this server.  |
 RoundTripTime  |
 Shows the time difference between the instance when a RADIUS request is sent and the corresponding response is received.  |
 AccessChallenges  |
 Shows the number of RADIUS access-challenges packets sent to this server. This does not include retransmission.  |
 NasIpAddress  |
 Shows the RADIUS client NAS Identifier for this server.  |
