You must first onboard the device and configure any optional IQ Agent parameters before you enable IQ Agent.
- In the navigation pane, expand
 - Select IQAgent.
 - Select the Globals tab.
 - Configure optional parameters as required.
 - Select Apply.
 - Select Enable.
 - Select Apply.
Use the data in the following table to use the Global tab to configure the ExtremeCloud IQ Agent.
                                 Name  |
                                 Description  |
                                 Enable  |
                                 Specifies whether IQ Agent is enabled. The default is enabled.  |
                                 Version  |
                                 Displays the ExtremeCloud IQ Agent firmware version running on the switch.  |
                                 OperStatus  |
                                 Displays the operational status of ExtremeCloud IQ Agent on the switch.  |
                                 ServerAddressType  |
                                 Specifies the address type of the ExtremeCloud IQ server address.  |
                                 Server/Address  |
                                 Specifies the ExtremeCloud IQ IPv4 address or DNS name. The default is hac.extremcloudiq.com.  |
                                 ServerAddressOrigin  |
                                 Specifies the origin for the ExtremeCloud IQ server address:
                                 Address  |
                                 Specifies the proxy IPv4 address or DNS name.  |
                                 TcpPort  |
                                 Specifies the TCP connection port.  |
                                 UserName  |
                                 Specifies the proxy server password.  |
                                 Password  |
                                 Specifies the proxy server username.  |
                                 AssociationUrl  |
                                 Displays the association URL of ExtremeCloud IQ.  |
                                 PollUrl  |
                                 Displays the poll URL of ExtremeCloud IQ.  |
                                 MonitorFreq  |
                                 Displays the monitoring frequency, in seconds, of ExtremeCloud IQ.  |
                                 PollFreq  |
                                 Displays the polling frequency, in seconds, of ExtremeCloud IQ.  |
                                 LastOnboardTime  |
                                 Displays the last onboard time of ExtremeCloud IQ.  |
                                 LastPollStatus  |
                                 Displays the last poll status of ExtremeCloud IQ.  |
                                 LastPollTime  |
                                 Displays the last poll time for a successful attempt.  |
                                 LastMonitorStatus  |
                                 Displays the last monitoring status of ExtremeCloud IQ.  |
                                 LastMonitorTime  |
                                 Displays the last monitor time for a successful attempt.  |
                                 LastHealthStatus  |
                                 Displays the last health status of ExtremeCloud IQ.  |
                                 LastHealthTime  |
                                 Displays the last health time for a successful attempt.  |
