Use the following procedure to display SPBM nicknames.
  1. In the navigation pane, expand Configuration > Fabric.
  2. Select SPBM.
  3. Select the Nick Names tab.
Nickname field descriptions
Use the data in the following table to use the NickName tab.
Name
Description
Level
Indicates the level at which the system displays this LSP.
ID
Indicates the 8 byte LSP ID, consisting of the SystemID, Circuit ID, and Fragment Number.
LifetimeRemain
Indicates the remaining lifetime in seconds for the LSP.
NickName
Indicates the nickname for the SPBM node.
HostName
Indicates the hostname listed in the LSP, or the IS-IS system name. The IS-IS system name uses global system name, if the host name is not configured.
