Table 1. IEEE 802.3X Pause Frame Transmit product support
Feature
Product
Release introduced
IEEE 802.3X Pause frame transmit
VSP 4450 Series
VOSS 6.0
VSP 4900 Series
VOSS 8.1
VSP 7200 Series
VOSS 6.0
VSP 7400 Series
VOSS 8.0
VSP 8200 Series
VOSS 6.0
VSP 8400 Series
VOSS 6.0
VSP 8600 Series
Not Supported
XA1400 Series
VOSS 8.1.50
The switch uses MAC pause frames to provide congestion relief on full-duplex interfaces.
When congestion occurs on a port, the system can send or receive pause frames, also known as flow control, to temporarily pause the packet flow. The system uses flow control if the rate at which one or more ports receives or sends packets is greater than the rate the switch can process or accept the packets.
The switch can generate pause frames to tell the sending device to stop sending additional packets for a specified time period. After the time period expires, the sending device can resume sending packets. During the specified time period, if the switch determines the congestion is reduced, it can send pause frames to the sending device to instruct it to begin sending packets immediately.
Flow control mode and pause frames
If you enable flow control mode, the switch drops packets on ingress when congestion occurs. If the switch is not in flow control mode, it drops packets at egress when congestion occurs.
Configure an interface to send pause frames when congestion occurs to alleviate packet drops due to flow control mode.
Interfaces that support auto-negotiation advertise and exchange their flow control capability to agree on a pause frame configuration. IEEE 802.3 annex 28b defines the auto-negotiation ability fields and the pause resolution. The switch advertises only two capabilities. The following table shows the software bit settings based on the flow control configuration.
Not all interfaces support Auto-Negotiation. For more information, see your hardware documentation.
Table 2. Advertised abilities
Interface configuration
Pause
ASM
Capability advertised
Flow control enabled
1
0
Symmetric pause
Flow control disabled
1
1
Both Symmetric pause and asymmetric pause
The following tables identifies the pause resolution.
Table 3. Pause resolution
Local device pause
Local device ASM
Peer device pause
Peer device ASM
Local device resolution
Peer device resolution
0
0
Do not care
Do not care
Disable pause transmit and receive.
0
1
0
Do not care
0
1
1
0
0
1
1
1
Enable pause transmit. Disable pause receive.
Disable pause transmit. Enable pause receive.
1
0
0
Do not care
1
Do not care
1
Do not care
Enable pause transmit and receive.
1
1
0
0
1
1
0
1
The following list identifies the type of interfaces that support auto-negotiated flow control:
