You can configure the Secure Hash Algorithm (SHA) level for password hash security. After a password hash level change, all custom users and passwords are deleted, and on first login each default user must change their default password.
  • You must use an account with read-write-all privileges to change password hash.
Configure the password hash level as SHA1 or SHA2.
    enable
    configure terminal
  2. Change the password hash level:
    password hash sha1|sha2
  3. Read the warning prompt, then confirm the password hash change:
    y
Switch:1>enable
Switch:1#configure terminal
Change password hash to SHA2 512-bit hash value:
Switch:1(config)# password hash sha2
Warning: Changing the password hash will reset all existing passwords and users to Factory defaults. All custom Users will be deleted. Are you sure you want to proceed (y/n) ? y
