This procedure does not apply to VSP 8600 Series.
Use this task to configure a DHCP Client on a management interface.
 - Select Mgmt.
 - Select the Dhcp tab.
 - In the Client field, select an option to configure the DHCP Client.
 - Select Apply.
Dhcp Field Descriptions
Use the data in the following table to use the Dhcp tab.
 Name  |
 Description  |
 Client  |
 Specifies the DHCP client configuration:
 ClientPreferredInterface  |
 Shows the DHCP Client preferred management interface when in cycle mode. On reboot, the system first attempts to aquire a DHCP IP address on the preferred interface.  |
