Use the ingress port-rate limiter to limit the traffic rate accepted by the specified ingress port. The port drops or re-marks violating traffic.
Variable definitions
Use the data in the following table to use the qos if-rate-limiting command.
 Variable  |
 Value  |
 1000-40000000  |
 Specifies the ingress rate limit in Kbps. The range is 1000–40000000.  |
 port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
