View port spanning tree statistics to manage network performance.
- In the Device Physical View, select a port.
 - Click Port.
 - Click the Spanning Tree tab.
Spanning Tree Field Descriptions
The following table describes parameters on the Spanning Tree tab.
 Name  |
 Description  |
 InConfigBpdus  |
 The number of Config BPDUs received.  |
 InTcnBpdus  |
 The number of Topology Change Notifications BPDUs received.  |
 InBadBpdus  |
 The number of unknown or malformed BPDUs received.  |
 OutConfigBpdus  |
 The number of Config BPDUs transmitted.  |
 OutTcnBpdus  |
 The number of Topology Change Notifications BPDUs transmitted.  |
