Perform this procedure to display configuration information for Endpoint Tracking.
Perform this procedure to display global, interface and binding information for Endpoint Tracking.
The following example displays all of the Endpoint Tracking configuration information for a switch.
Switch:1>show endpoint-tracking
                          Endpoint Tracking Configuration
                            endpoint tracking status : ENABLED
                              auto-isid-offset value : 15990000
                            auto-isid-offset enabled : ENABLED
                              visibility-mode status : ENABLED
            Switch:1>show endpoint-tracking interfaces
                                 Endpoint Tracking Interfaces
PORT
NUM      INDEX      STATUS
1/1        192      Enabled
1/10       201      Enabled
MLT-2      6145     Enabled
MLT-5      6148     Disabled
4 out of 4 Total Num of Endpoint Tracking interfaces displayed
            Switch:1>show endpoint-tracking bindings summary
                                               Endpoint Tracking Bindings
PORT/MLT  INDEX  TOTAL   ACCEPTED   REJECTED   PENDING   TIMEOUT   SERVER-UNREACHABLE
1/10      201    5       5          0          0         0         0
PORT/MLT  INDEX  MAC                STATUS   VLAN ID  ISID     SOURCE       TIMEOUT             TIME REMAINING
1/10      201    00:00:00:00:1b:01  accept   27       15990027 autoconfig   0 day(s), 00:01:40  0 day(s), 00:00:00
1/10      201    00:00:00:00:1b:02  accept   27       15990027 autoconfig   0 day(s), 00:01:40  0 day(s), 00:00:00
1/10      201    00:00:00:00:1b:03  accept   27       15990027 autoconfig   0 day(s), 00:01:40  0 day(s), 00:00:00
1/10      201    00:00:00:00:1b:04  accept   27       15990027 autoconfig   0 day(s), 00:01:40  0 day(s), 00:00:00
1/10      201    00:00:00:00:1b:05  accept   27       15990027 autoconfig   0 day(s), 00:01:40  0 day(s), 00:00:00
5 out of 5 Total Num of Endpoint Tracking bindings displayed.
The following table defines parameters for the show endpoint-tracking bindings command.
                                 Variable  |
                                 Value  |
                                 gigabitEthernet {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
                                 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
                                 MLT <1-512>  |
                                 Specifies the MLT ID.  |
                                 summary  |
                                 Provides a summary of the total number and status of bindings for all interfaces.  |
