This procedure does not apply to VSP 8600 Series.
Use this task to configure or view IPv6 address information for a Segmented Management Instance.
Ensure the IP address you plan to assign is not in use by an existing VLAN or CLIP IP subnet configured on the switch.
 - Select Mgmt Instance.
 - Select Mgmt.
 - Select the Ipv6Address tab.
 - Select Insert.
 - Select the Segmented Management Instance interface type.
 - Type the address information.
 - Select Insert.
Ipv6Address Field Descriptions
Use the data in the following table to use the Ipv6Address tab.
 Name  |
 Description  |
 InstanceId  |
 Specifies the interface instance.  |
 Address  |
 Specifies the IPv6 address for the interface instance. Ensure that the management CLIP IP address does not fall into the range of a configured VLAN IP address range as this is not allowed.  |
 PrefixLength  |
 Specifies the prefix length for the IPv6 address.  |
 AddrOrigin  |
 Shows the IPv6 address origin.  |
                 IntfName  |
                 Shows the interface name.  |
                 DadStatus  |
                 Shows the IPv6 DAD status of the address.  |
