Use the following procedure to configure IS-IS interface level parameters. SPBM uses IS-IS to discover network topology, build shortest path trees between network nodes, and communicate network information in the control plane.
Interfaces Level Field Descriptions
Use the data in the following table to use the Interfaces Level tab.
 Name  |
 Description  |
 Index  |
 The identifier of this circuit, unique within the Intermediate System. This value is for SNMP Indexing purposes only and need not have any relation to any protocol value.  |
 Level  |
 Specifies the router type globally:
 The default value is l1.  |
 ISPriority  |
 Specifies an integer sub-range for IS-IS priority. The default is 64.  |
 HelloTimer  |
 Configures the level 1 hello interval. Specifies the maximum period, in milliseconds, between IS-IS Hello Packets (IIH) PDUs on multiaccess networks at this level for LANs. The value at Level1 is used as the period between Hellos on Level1/Level2 point to point circuits. Setting this value at Level 2 on an Level1/Level2 point-to-point circuit results in an error of InconsistentValue. The default value is 9000 milliseconds or 9 seconds.  |
 HelloMultiplier  |
 Configures the level 1 hello multiplier. The default value is 3 seconds.  |
 DRHelloTimer  |
 Indicates the period, in milliseconds, between Hello PDUs on multiaccess networks when this Intermediate System is the Designated Intermediate System. The default is 3.  |
