Use this procedure to view TCP and UDP configuration information for IPv4.
Switch:1#show ip tcp connections
                           TCP connection table info
LOCALPORT    LOCALADDR            REMOTEPORT   REMOTEADDR           STATE           VRF ID
21           0.0.0.0              0            0.0.0.0              listen          0
22           0.0.0.0              0            0.0.0.0              listen          0
23           0.0.0.0              0            0.0.0.0              listen          0
80           0.0.0.0              0            0.0.0.0              listen          0
443          0.0.0.0              0            0.0.0.0              listen          0
23           192.0.2.146       52583        198.51.100.30        established     0
Switch:1#show ip tcp properties show ip tcp global properties command: ------------------ RtoAlgorithm constant RtoMin 5002 milliseconds RtoMax 60128 milliseconds MaxConn 127
Switch:1#show ip tcp statistics show ip tcp global statistics: ------------------ ActiveOpens: 0 PassiveOpens: 37 AttemptFails: 0 EstabResets: 34 CurrEstab: 1 InSegs: 6726 OutSegs: 7267 RetransSegs: 10 InErrs: 0 OutRsts: 10
Switch:1#show ip udp endpoints
                            UDP endpoint table info
LOCALPORT    LOCALADDRESS         REMOTEPORT   REMOTEADDRESS        PROCESS    INSTANCE
26           0.0.0.0 0            0.0.0.0 1          0
67           0.0.0.0 0            0.0.0.0 1          0
69           0.0.0.0 0            0.0.0.0 1          0
161          0.0.0.0 0            0.0.0.0 1          0
Switch:1#show ip udp statistics show ip udp info: --------------------------------------------------------------------------------------- InDatagrams: 887 NoPorts: 0 InErrors: 0 OutDatagrams: 887 HCInDatagrams: 887 HCOutDatagrams: 887
Variable definitions
Use the data in the following table to use the show ip tcp command.
 Variable  |
 Value  |
 connections  |
 Specifies the TCP connection information. Use the following parameters:
 Example: show ip tcp connections vrf 0  |
 properties  |
 Specifies the TCP global properties information.  |
 statistics  |
 Specifies the TCP global statistics.  |
 Variable  |
 Value  |
 endpoints  |
 Specifies the IP UDP endpoint information.  |
 statistics  |
 Specifies IP UDP statistics information.  |
