Use this procedure to display information about the learned multicast groups in the cache.
- In the navigation pane, expand the following folders: .
 - Click IPv6 MLD.
 - Click the Cache tab.
MLD cache field description
Use the data in the following table to use the Cache tab.
 Field  |
 Description  |
 Address  |
 The IPv6 multicast group address for which this entry contains information.  |
 IfIndex  |
 Indicates the internetwork-layer interface for which this entry contains information for an IPv6 multicast group address.  |
 LastReporter  |
 Indicates the source IPv6 address of the last membership report received for this IPv6 Multicast group address on this interface. If membership report is not received, the value is 0::0  |
 ExpiryTime  |
 Indicates the minimum amount of time remaining before the entry ages out.  |
