This procedure only applies to VSP 8600 Series.
Use this procedure to view non-EAPoL client MAC information on a port.
Use the clear-stats command to clear EAP and NEAP statistics.
Not all fields are supported on all hardware platforms.
Switch:1(config)#show eapol multihost non-eap-mac status
                         Eap Oper Status
PORT  MAC               STATE         VLAN  PRI  Flex-UNI  I-SID      NON-EAP VLAN:I-SID
NUM                                   ID         Enable    SOURCE     AUTH    AUTH
1/10  00:00:00:00:00:0e authenticated 10    2    true      autoconfig radius  0:1015
Total Number of EAP Sessions: 1
            Switch(config-if)#show eapol multihost non-eap-mac status verbose
                                                        Non-Eap Oper Status Verbose
PORT  MAC                STATE             VLAN  PRI  Flex-UNI  I-SID        NON-EAP  VLAN:I-SID    ACL  ACEs
2/11  00:00:00:00:01:02  authenticated     N/A   0    true      radius       radius   0:10555
Total Number of NEAP Sessions: 1
Use the data in the following table to use the show eapol multihost non-eap-mac status command.
                                 Variable  |
                                 Value  |
                                 {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
                                 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
                                 <1-4059>  |
                                 Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.  |
                                 verbose  |
                                 Displays non-EAPoL client MAC information.  |
