Perform this procedure to specify serial port communication settings. The serial port on the device is the console port. Depending on the hardware platform, the console port displays as console or 10101.
- In the Device Physical View tab, select the console port on the device.
 - Click Serial Port.
 - Edit the port parameters as required.
 - Click Apply.
Serial Port Field Descriptions
Use the data in the following table to use the Serial Port tab.
                                 Name  |
                                 Description  |
                                 IfIndex  |
                                 Identifies the port as a serial port.  |
                                 BaudRate  |
                                 Specifies the baud rate of this port. Different hardware platforms support different baud rates, which also impacts the default value for each hardware platform:
                                 DataBits  |
                                 Specifies the number of data bits, for each byte of data, this port sends and receives. The default is eight.  |
