 - Select BFD.
 - Select Insert.
 - In the NextHop field, type the IPv4 address of the next hop of the BFD session.
 - Optional: In the VrfId field, type the ID of the VRF associated with the BFD session.
BFD Static Route Field Descriptions
Use the data in the following table to use the Static Route tab.
| Name | Description |
                                 NextHop  |
                                 Specifies the IPv4 address of the next hop of the BFD session.  |
                                 VrfId  |
                                 Specifies the ID of the VRF associated with the BFD session.  |
                                 VrfName  |
                                 Specifies the name of the VRF associated with the BFD session.  |
