View topology message status to view the interconnections between Layer 2 devices in a network.
 - Click Topology.
 - Click the Topology Table tab.
Topology Table Field Descriptions
Use the data in the following table to use the Topology Table tab.
 Name  |
 Description  |
 Slot  |
 Specifies the slot number in the chassis that received the topology message.  |
 Port  |
 Specifies the port that received the topology message.  |
 SubPort  |
 Specifies the channel of a channelized 40 Gbps port that received the topology message.  |
 IpAddr  |
 Specifies the IP address of the sender of the topology message.  |
 SegId (RemPort)  |
 Specifies the segment identifier of the segment from which the remote agent sent the topology message. This value is extracted from the message.  |
 MacAddr  |
 Specifies the MAC address of the sender of the topology message.  |
 ChassisType  |
 Specifies the chassis type of the device that sent the topology message.  |
 BkplType  |
 Specifies the backplane type of the device that sent the topology message.  |
 LocalSeg  |
 Indicates if the sender of the topology message is on the same Ethernet segment as the reporting agent.  |
 CurState  |
 Specifies the current state of the sender of the topology message. The choices are
