Use the following procedure to display information about the IPFIX collector. The IPFIX collector can store flow information from multiple network devices.
                                                  IPFIX Collector-Info
ID   Collector         Exporter          Source   Destination   Collector   Reachable         Exporting   Initial
     IP Address        IP Address        Port     Port          State       Via               Interval    Burst
1    20.20.20.2        20.20.20.1        2055     2055          Enabled     -                 60          5
Use the data in the following table to use the show ip ipfix collector command.
 Variable  |
 Value  |
 <1–1>  |
 Specifies the IPFIX collector ID.  |
