This procedure only applies to VSP 8600 Series.
Perform this procedure to view information about the operating status of the power supplies.
 - Select Power Supply Information.
Details Field Descriptions
Use the data in the following table to use the Details tab.
 Name  |
 Description  |
 Id  |
 Specifies the ID number. This field is not supported on all hardware platforms.  |
 Type  |
 Describes the type of power used.  |
 Description  |
 Provides a description of the power supply.  |
 SerialNumber  |
 Specifies the power supply serial number.  |
 HardwareRevision  |
 Specifies the hardware revision number.  |
 PartNumber  |
 Specifies the power supply part number.  |
 PowerSupplyOperStatus  |
 Specifies the status of the power supply as one of the following:
 InputLineVoltage  |
 Displays the input line voltage:
 OutputWatts  |
 Displays the output power of this power supply.  |
 InputOperLineVoltage  |
 Displays the operating input line voltage. If the power supplies in a chassis are not of identical input line voltage values, the operating line voltage shows the low 110v value. This field is not supported on all hardware platforms.  |
 InputPower  |
 Displays the input power of this power supply. This field is not supported on all hardware platforms.  |
