Use this procedure to configure the maximum EAP clients allowed on the port at one time.
Configure the maximum EAP clients allowed on the port at one time.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitEthernet 1/1 Switch:1(config)#eapol multihost eap-mac-max 10
The following table defines parameters for the eapol multihost eap-mac-max command.
 Variable  |
 Value  |
 <0–32>  |
 Specifies the maximum EAP clients allowed on the port at one time. The default is 2.  |
