Use this procedure to view the remote device information received through the Industry Standard Discovery Protocol (ISDP) (CDP-compatible) messages on the local interface.
 - Select LLDP.
 - Select the CDP Remote tab.
CDP Remote Field Descriptions
Use the data in the following table to use the CDP Remote tab.
                             Name  |
                             Description  |
                             PortNum  |
                             Indicates the port number on which the remote system information is received.  |
                             CallServers  |
                             Indicates the remote call server IP addresses that are received on this port.  |
                             FileServers  |
                             Indicates remote file server IP addresses that are received on this port.  |
