Perform the following procedure to configure the PoE power priority for a port or list of ports. You can configure the PoE power priority of ports to manage availability of the connected PDs. If the switch needs to shut down PDs because PoE exceeds the power limit threshold, low priority devices are shut down before high priority, and high priority are shut down before critical.
The following table defines parameters for the poe-priority command.
 Variable  |
 Value  |
 <portlist>  |
 Identifies the ports to set priority for.  |
 {low | high | critical}  |
 Identifies the PoE priority.  |
