This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure the remote SPBM interface parameters.
 - Select SPBM Remote.
 - Select the Interfaces SPBM tab.
 - Select Insert to create a remote SPBM instance on the interface.
 - Configure the remote SPBM interface parameters.
 - Select Insert.
Interfaces SPBM Field Descriptions
Use the data in the following table to use the Interfaces SPBM tab.
                         Name  |
                         Description  |
                         Index  |
                         Specifies an Index value for the remote SPBM interface.  |
                         SpbmId  |
                         Specifies the remote SPBM ID.  |
                         State  |
                         Specifies whether the remote SPBM interface is enabled or disabled.  |
                         Type  |
                         Configures the remote SPBM instance interface-type on the IS-IS interface on the specific port or MLT, the values are point-to-point (ptpt) or broadcast (bcast). The system supports the ptpt interface type only.  |
                         L1Metric  |
                         Configures the remote SPBM instance l1-metric on the IS-IS interface on the specific port or MLT. The default value is 10.  |
| Origin |
                                 Specifies the source of the remote SPBM instance configuration.
