View IPv6 PIM-SM neighbor parameters to troubleshoot connection problems or review the configuration.
- In the navigation pane, expand the following folders: .
 - Click IPv6 PIM.
 - Click the Neighbors tab.
Neighbors field descriptions
Use the descriptions in the following table to use the Neighbors tab.
 Name  |
 Description  |
 Address  |
 Shows the IPv6 address of the PIM neighbor.  |
 IfIndex  |
 Shows the slot and port number or VLAN ID of the interface used to reach this PIM neighbor.  |
 UpTime  |
 Shows the time since this neighbor became a neighbor of the local router.  |
 ExpiryTime  |
 Shows the time remaining before the neighbor expires.  |
