You can create a graph of the port statistics to generate a visual
representation of your data.
- In the Device Physical
View, select the port or ports for which you want to create a graph.
 - In the navigation pane,
expand the  folders, and then click Port.
OR, use the following shortcut:
Right-click the selected port or ports from Step 1, and choose Graph.
 - On the Graph Port tab for the selected port or ports, select the item you want to
graph.
 - Click an icon to select
the type of graph you require. The following list provides the graph
types available:
Line Chart
Area Chart
Bar Chart
Pie Chart
