Switch:1>show ip vrrp address
                            VRRP Info - GlobalRouter
VRRP ID  P/V      IP              MAC                STATE    CONTROL  PRIO  ADV VERSION  ORIGIN
3        3        30.30.30.99     00:00:5e:00:01:03  Master   Enabled  100   1   2        config
2        1/1      20.20.20.99     00:00:5e:00:01:02  Master   Enabled  100   1   3        config
2 out of 2 Total Num of VRRP Address Entries displayed.
VRRP ID  P/V      MASTER          UP TIME               HLD DWN  CRITICAL IP(ENABLED)  VERSION  HOSTNAME
3        3        30.30.30.18     0 day(s), 00:08:53    0        0.0.0.0    (No)       2
2        1/1      20.20.20.18     0 day(s), 00:02:01    0        0.0.0.0    (No)       3
VRRP ID  P/V      BACKUP MASTER   BACKUP MASTER STATE   FAST ADV (ENABLED)     VERSION
3        3        disable         down                  200       (NO)          2
2        1/1      disable         down                  200       (NO)          3
The following table defines parameters for the show ip vrrp address command.
 Variable  |
 Value  |
 addr <A.B.C.D>  |
 Specifies the physical local address of the master VRRP.  |
 vrf WORD<1-16>  |
 Specifies the name of the VRF.  |
 vrid <1-255>  |
 Specifies a unique integer value that represents the virtual router ID. The virtual router acts as the default router for one or more assigned addresses.  |
 vrfids WORD<0-512>  |
 Specifies the ID of the VRF.  |
 version <2–3>  |
 Specifies the VRRP version to include in the command output.  |
