Configure route advertisement in IPv6 on the management port for neighbor discovery (ND).
This procedure supports Layer 2 or Layer 3 route advertisement on VSP 8600 Series only.
  1. Enter mgmtEthernet Interface Configuration mode:
    enable
    configure terminal
    interface mgmtEthernet <mgmt | mgmt2>
  2. Configure the number of neighbor solicitation messages from duplicate address detection:
    ipv6 nd dad-ns <0–600>
  3. Configure the hop limit sent in router advertisements:
    ipv6 nd hop-limit <0–255>
Switch:1(config-if)#ipv6 nd dad-ns 2
Switch:1(config-if)#ipv6 nd hop-limit 2
Switch:1#show ipv6 nd interface mgmtethernet mgmt
                                             Mgmt Ipv6 Nd
IFID MGMT-IF RTR-ADV MAX-INT MIN-INT LIFETIME MANAG OTHER DAD-NS MTU HOP REACHABLE RETRANSMIT
                                             FLAG  CONF             LIMIT  TIME      TIME
64   mgmt   False   600     200      0      False  False 2      0(d) 2(s)   0(d)    0(d)
Note:  (s)= Set, (d)= Default, (i)= inherit.
1 out of 5 Total Num of IPv6 ND Entries displayed.
Variable definitions
Use the data in the following table to use the ipv6 nd command.
Variable
Value
dad-ns <0–600>
Specifies the number of neighbor solicitation messages for duplicate address detection (DAD).
A value of 0 disables the DAD process on this interface.
A value of 1 sends one advertisement without retransmissions.
The default is 1.
hop-limit <0–255>
Specifies the current hop limit field sent in router advertisements from this interface.
The value must be the current diameter of the Internet.
A value of zero indicates that the advertisement does not specify a hop-limit value.
The default is 64.
