View application host statistics to see traffic statistics by application protocol for each host.
 - Click Application Layer Host.
 - Click the Application Host Stats tab.
Application Host Stats Field Descriptions
Use the data in the following table to use the Application Host Stats tab.
 Name  |
 Description  |
 Index  |
 Shows a unique identifier for the entry in the table.  |
 HostAddress  |
 Identifies the network layer address of this entry.  |
 LocalIndex  |
 Identifies the network layer protocol of the address.  |
 InPkts  |
 Shows the number of packets for this protocol type, without errors, transmitted to this address. This value is the number of link-layer packets so a single, fragmented network-layer packet can increment the counter several times.  |
 OutPkts  |
 Shows the number of packets for this protocol type, without errors, transmitted by this address. This value is the number of link-layer packets so a single, fragmented network-layer packet can increment the counter several times.  |
 InOctets  |
 Shows the number of octets transmitted to this address, excluding octets in packets that contained errors. This value counts octets in the entire packet that contained the protocol, not just the particular protocol frames.  |
 OutOctets  |
 Shows the number of octets transmitted by this address, excluding octets in packets that contained errors. This value counts octets in the entire packet that contained the protocol, not just the particular protocol frames.  |
 CreateTime  |
 Shows the value of the sysUpTime when the entry was last activated.  |
