Important
Upgrades from some releases require release-specific steps. For more information, see VOSS Release Notes.
Perform this procedure to upgrade the software on the switch. This procedure shows how to upgrade the software using the internal flash memory as the file storage location.
Use one of the following options to upload the file with the new software to the switch:
Use FTP or SFTP to transfer the file.
Download the image file to your computer. Copy the file to a USB device and insert the USB device into the USB port on the switch.
You can store up to six software releases on the switch. If you have six releases already stored on the switch, you are prompted to remove one release before you can proceed to add and activate a new software release.
For information about how to remove a software release, see Remove a Software Build.
To obtain the new software, go to the Extreme Networks support site: http://www.extremenetworks.com/support. You need a valid user or site ID and password.
Back up the configuration files.
Use an FTP or SFTP application or USB device to transfer the file with the new software release to the switch.
Ensure that you have not configured a VLAN above 4059. If you have, you must port all configuration on this VLAN to another VLAN, before you begin the upgrade.
Caution
Only VLAN range 2 to 4059 is supported. All configuration on a higher numbered VLAN from earlier releases will be lost after the upgrade.
Software upgrade configurations are case-sensitive.
The image file name is switch dependent. See VOSS Release Notes for information about file names.
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch:1(config)#boot config flags ftpd
Switch:1#end
Switch:1#copy /usb/VOSS8200.8.5.0.0.tgz /intflash/VOSS8200.8.5.0.0.tgz
Switch:1#software add VOSS8200.8.5.0.0.tgz
Switch:1#software activate VOSS8200.8.5.0.0.GA
Switch:1#reset -y
Switch:1#show software
software releases in /intflash/release/
VOSS8200.8.5.0.0.GA (Primary Release)(Signed Release)
VOSS8200.8.4.2.0.GA (Backup Release) (Unsigned Release)
Auto Commit : enabled
Commit Timeout : 10 minutes
Remaining time until software auto-commit is 8 minutes 59 seconds
Switch:1#show software detail
VOSS8200.8.5.0.0.GA(Primary Release) (Signed Release)
SSIO
UBOOT 18081615
KERNEL 4.9
ROOTFS 4.9
APP_FS VOSS8200.8.5.0.0.GA
AVAILABLE ENCRYPTION MODULES
3DES
AES/DES
SSIO
UBOOT 18081615
KERNEL 4.9
ROOTFS 4.9
APP_FS VOSS8200.8.4.2.0.GA
No Modules Added
Remaining time until software auto-commit is 8 minutes 41 seconds
Switch:1#software commit
Executing software commit for version VOSS8200.8.5.0.0.GA.
Software commit successful
The following table defines parameters for the software command.
| Variable | Value |
| activate WORD<1-99> |
Copies the software version to the boot flash file. When you use the software activate command, the system checks for hardware dependencies and prevents a downgrade if it detects a dependency. For example, if a hardware component has a minimum software version dependency, you cannot downgrade to an incompatible software version or install the hardware component in a chassis that runs an incompatible software version. |
| add WORD<1-99> |
Unpacks a software release <version>. |
