Feature |
Product |
Release introduced |
DvR Controller Important:
Because of a change in VOSS 6.0.1.2, the best practice is to use a minimum software version of 6.0.1.2 in DvR deployments. |
VSP 4450 Series |
Not Supported |
VSP 4900 Series |
VOSS 8.1.5 VSP4900-12MXU-12XE, VSP4900-24S, and VSP4900-24XE only |
VSP 7200 Series |
VOSS 6.0.1 |
VSP 7400 Series |
VOSS 8.0 |
VSP 8200 Series |
VOSS 6.0.1 |
VSP 8400 Series |
VOSS 6.0.1 |
VSP 8600 Series |
VSP 8600 8.0 |
XA1400 Series |
Not Supported |
DvR Isolated Domains |
VSP 4450 Series |
Not Supported |
VSP 4900 Series |
VOSS 8.8 VSP4900-12MXU-12XE, VSP4900-24S, and VSP4900-24XE only |
VSP 7200 Series |
VOSS 8.8 |
VSP 7400 Series |
VOSS 8.8 |
VSP 8200 Series |
VOSS 8.8 |
VSP 8400 Series |
VOSS 8.8 |
VSP 8600 Series |
Not Supported |
XA1400 Series |
Not Supported |
dvr-one-ip |
VSP 4450 Series |
Not Supported |
VSP 4900 Series |
VOSS 8.3 VSP4900-12MXU-12XE, VSP4900-24S, and VSP4900-24XE only |
VSP 7200 Series |
VOSS 8.3 |
VSP 7400 Series |
VOSS 8.3 |
VSP 8200 Series |
VOSS 8.3 |
VSP 8400 Series |
VOSS 8.3 |
VSP 8600 Series |
VSP 8600 8.0 |
XA1400 Series |
Not Supported |
DvR In-band Management |
VSP 4450 Series |
Not Supported |
VSP 4900 Series |
VOSS 8.1 VSP4900-12MXU-12XE, VSP4900-24S, and VSP4900-24XE only |
VSP 7200 Series |
VOSS 6.0.1 |
VSP 7400 Series |
VOSS 8.0 |
VSP 8200 Series |
VOSS 6.0.1 |
VSP 8400 Series |
VOSS 6.0.1 |
VSP 8600 Series |
Not supported |
XA1400 Series |
Not Supported |
DvR-VRRP Coexistence Important:
To use this functionality, you must upgrade the software on all DvR BEBs, including Leaf nodes, to at least the minimum software version to support this functionality. |
VSP 4450 Series |
Not Supported |
VSP 4900 Series |
VSP 7200 Series |
VOSS 8.8 |
VSP 7400 Series |
VOSS 8.8 |
VSP 8200 Series |
VOSS 8.8 |
VSP 8400 Series |
VOSS 8.8 |
VSP 8600 Series |
Not Supported |
XA1400 Series |
Not Supported |
Feature |
Product |
DvR Leaf Important:
VSP 4450 Series |
VOSS 6.1 |
VSP 4900 Series |
VOSS 8.1 |
VSP 7200 Series |
VOSS 6.0.1 |
VSP 7400 Series |
VOSS 8.0 |
VSP 8200 Series |
VOSS 6.0.1 |
VSP 8400 Series |
VOSS 6.0.1 |
VSP 8600 Series |
Not supported |
XA1400 Series |
Not Supported |
VSP 4450 Series |
VOSS 6.1 |
VSP 4900 Series |
VOSS 8.1 |
VSP 7200 Series |
VOSS 6.0.1 |
VSP 7400 Series |
VOSS 8.0 |
VSP 8200 Series |
VOSS 6.0.1 |
VSP 8400 Series |
VOSS 6.0.1 |
VSP 8600 Series |
Not supported |
XA1400 Series |
Not Supported |
Management I-SID Assignment to DvR Leaf |
VSP 4450 Series |
VOSS 8.5 |
VSP 4900 Series |
VOSS 8.5 |
VSP 7200 Series |
VOSS 8.5 |
VSP 7400 Series |
VOSS 8.5 |
VSP 8200 Series |
VOSS 8.5 |
VSP 8400 Series |
VOSS 8.5 |
VSP 8600 Series |
Not Supported |
XA1400 Series |
Not Supported |
Distributed Virtual Routing (DvR) is a technology for router redundancy in a Fabric deployment where IP subnets are stretched across multiple switches. DvR provides Default Gateway Redundancy and optimizes traffic flows to avoid traffic tromboning due to inefficient routing, thereby increasing the total routing throughput.
The topics in this section provide DvR concepts and configuration procedures.
