This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure the area virtual node parameters like system name, system ID, and nickname on the remote Intermediate-to-Intermediate-System (IS-IS) instance.
 - Select IS-IS Remote.
 - Select the Area VNode tab.
 - Configure the parameters.
 - Select Apply.
Area VNode Field Descriptions
Use the data in the following table to use the Area VNode tab.
| Name | Description |
                                 VNodeNickName  |
                                 Specifies the nickname of the virtual node on remote IS-IS instance.  |
                                 VNodeSysId  |
                                 Specifies the system ID of the virtual node on remote IS-IS instance.  |
                                 VNodeSysName  |
                                 Specifies the system name of the virtual node on remote IS-IS instance.  |
