This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure Multi-area SPB layer 3 redistribution in the home area.
 - Select MultiArea.
 - Select the L3 Redist Home tab.
 - Select Insert.
 - In the VrfId field, type the Virtual Router Forwarding ID.
 - In the Type field, select the layer 3 redistribution type.
 - Optional: In the RoutePolicy field, type the name of the redistribution policy.
 - Select Enable.
 - In the Apply field, select apply.
 - Select Insert.
L3 Redist Home Field Descriptions
Use the data in the following table to use the L3 Redist Home tab.
| Name | Description |
                                 VrfId  |
                                 Specifies the Virtual Router Forwarding ID.  |
                                 Type  |
                                 Specifies the layer 3 redistribution type. The options are:
                                 RoutePolicy  |
                                 Associates a route policy to a specific layer 3 redistribution entry in the home area.  |
                                 Enable  |
                                 Enables layer 3 redistribution in the home area. The default value is disabled.  |
                                 Apply  |
                                 Applies the Multi-area SPB layer 3 redistribution filters in the home area. The default value is noAction.  |
