Viewing VLAN information
View the VLAN information to display the basic configuration for all VLANs or a specified VLAN.
  1. To enter User EXEC mode, log on to the switch.
  2. View VLAN information:
    show vlan basic <1-4059>
  3. View advanced parameters:
    show vlan advance <1-4059>
View VLAN information for VLAN 2:
Switch:1> show vlan basic 2
                                Vlan Basic
VLAN                           INST
ID    NAME          TYPE         ID  PROTOCOLID SUBNETADDR  SUBNETMASK  VRFID  ORIGIN
2     VLAN-2       byPort       0   none       N/A          N/A	      0     CONFIG
                                 Vlan Basic
VLAN                            INST
1     Default        byPort       0   none       N/A          N/A	    0      CONFIG
2     abc            byPort       0   none       N/A          N/A	    0      CONFIG
3     VLAN-VRRP      byPort       0   none       N/A          N/A	    0      CONFIG
4     VLAN-6         byPort       0   none       N/A          N/A	    1      CONFIG
5     VLAN-7         byPort       0   none       N/A          N/A	    1      CONFIG
6     VLAN-8         byPort       0   none       N/A          N/A	    1      CONFIG
19    VLAN-9         byPort       0   none       N/A          N/A	    0      CONFIG
10    VLAN-10        byPort       0   none       N/A          N/A	    0      CONFIG
11    VLAN-11        byPort       0   none       N/A          N/A	    0      CONFIG
12    VLAN-12        byPort       0   none       N/A          N/A	    0      CONFIG
13    VLAN-13        spbm-bvlan   62  none       N/A          N/A	    0      CONFIG
14    VLAN-14        spbm-bvlan   62  none       N/A          N/A	    0      CONFIG
15    VLAN-15        byPort       1   none       N/A          N/A	    0      CONFIG
--More-- (q = quit)
Switch:1> show vlan advance
                                  Vlan Advance
VLAN             IF    AGING MAC                USER
ID    NAME       INDEX TIME  ADDRESS            DEFINEPID ENCAP  DSAP/SSAP
2     Default 2050  0     00:24:7f:9f:6a:03  0x0000
Use the data in the following table to use optional parameters with the show vlan basic and show vlan advance commands.
Variable
Value
<1-4059>
Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.
