Perform this procedure to filter on specific Ethernet source addresses.
The ACL exists.
The ACE exists.
 - Click Advanced Filters (ACE/ACLs).
 - Click the ACL tab.
 - Select the appropriate ACL.
 - Click ACE.
 - Select the appropriate ACE.
 - Click Eth.
 - Click the Source Address tab.
 - Click Insert.
 - Specify the ACE Ethernet operation.
 - In the List dialog box, specify the Ethernet source address.
 - Click Insert.
Source Address Field Descriptions
Use the data in the following table to use the Source Address tab.
 Variable  |
 Value  |
 AclId  |
 Specifies the ACL ID.  |
 AceId  |
 Specifies the ACE ID.  |
 Oper  |
 The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits.  |
 List  |
 Specifies the MAC address to match.  |
 OperMask  |
 Specifies the MAC Address mask value in hexadecimal format. The value for this variable is empty or 000000000000 if the Oper variable is eq.  |
