Add a user to a group to logically group users who require the same level of access.
Add a user to a group to logically group users who require the same level of access:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#snmp-server user test4 group grouptest4 md5 aes
Enter the authentication protocol password : ********
Re-enter the authentication protocol password : ********
Enter the privacy protocol password : ********
Re-enter the privacy protocol password : ********
WARNING: For best security practices avoid the use
         of repeated patterns in passwords.
Switch:1(config)#show snmp-server group
                      VACM Group Membership Configuration
Sec Model  Security Name                  Group Name
snmpv1     readview                       readgrp
snmpv1     initialview                    v1v2grp
snmpv2c    readview                       readgrp
snmpv2c    initialview                    v1v2grp
usm        test1                          Grouptest1
usm        test2                          geet1
usm        test4                          grouptest4
7 out of 7 Total entries displayed
                        VACM Group Access Configuration
Group      Prefix Model   Level        ReadV      WriteV     NotifyV
initial           usm     noAuthNoPriv root       root       root
initial           usm     authPriv     root       root       root
initial    vrf512 usm     noAuthNoPriv vrf        vrf        vrf
initial    vrf512 usm     authPriv     vrf        vrf        vrf
readgrp           snmpv1  noAuthNoPriv v1v2only              org
readgrp           snmpv2c noAuthNoPriv v1v2only              org
readgrp    vrf512 snmpv1  noAuthNoPriv vrf                   vrf
readgrp    vrf512 snmpv2c noAuthNoPriv vrf                   vrf
v1v2grp           snmpv1  noAuthNoPriv v1v2only   v1v2only   v1v2only
v1v2grp           snmpv2c noAuthNoPriv v1v2only   v1v2only   v1v2only
v1v2grp    vrf512 snmpv1  noAuthNoPriv vrf        vrf        vrf
v1v2grp    vrf512 snmpv2c noAuthNoPriv vrf        vrf        vrf
12 out of 12 Total entries displayed
The following table defines parameters for the snmp-server user command.
 Variable  |
 Value  |
 {aes|des}  |
 Specifies a privacy protocol. If no value is entered, no authentication capability exists. The choices are aes or des. Important:
You must set authentication before you can set the privacy option.  |
 engine-id WORD<16-97>  |
 Assigns an SNMPv3 engine ID. Use the no operator to remove this configuration.  |
 group WORD<1-32>  |
 Specifies the group access name.  |
 {md5|sha}  |
 Specifies an authentication protocol. If no value is entered, no authentication capability exists. The protocol choices are: MD5 and SHA.  |
 notify-view WORD<0-32>  |
 Specifies the view name in the range of 0 to 32 characters. The first instance is a noAuth view. The second instance is an auth view and the last instance is an authPriv view.  |
 read-view WORD<0-32>  |
 write-view WORD<0-32>  |
 user WORD<1-32>  |
 Creates the new entry with this security name. The name is used as an index to the table. The range is 1–32 characters. Use the no operator to remove this configuration.  |
