View DHCP Relay information to display the current configuration for the forwarding path and the interface configuration.
Not all parameters are available in non-default VRFs.
Switch:1(config-if)#show ipv6 dhcp-relay fwd-path
                         DHCPv6 Fwd-path - GlobalRouter
INTERFACE                           SERVER                              ENABLE
1111:0:0:0:0:0:0:1111               1234:0:0:0:0:0:0:1234               enable
Use the information in the following table to help you use the show ipv6 dhcp-relay command.
                             Variable  |
                             Value  |
                             {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
                             Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
                             vlan<1-4059>  |
                             Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.  |
                             vrf WORD<1–16>  |
                             Specifies the VRF name.  |
                             vrfids WORD<0–512>  |
                             Specifies the VRF ID.  |
