Viewing IP VRRPv3 Statistics
Use the following procedure to view IP VRRPv3 statistics to monitor network performance.
View IP VRRPv3 statistics:
Switch:1#show ip vrrp statistics
                        VRRP Global Stats - GlobalRouter
CHK_SUM_ERR   VERSION_ERR   VRID_ERR      VRRP_VERSION
0             0             0             2
0             0             0             3
                      VRRP Interface Stats - GlobalRouter
VRRP ID  P/V      BECOME_MASTER ADVERITSE_RCV VERSION
3        3        1             0             2
2        1/1      1             0             3
VRRP ID  P/V      ADVERTISE_INT_ERR TTL_ERR       PRIO_0_RCV    VERSION
3        3        0                 0             0             2
2        1/1      0                 0             0             3
VRRP ID  P/V      PRIO_0_SENT   INVALID_TYPE_ERR ADDRESS_LIST_ERR UNKNOWN_AUTHTYPE    VERSION
3        3        0             0                0                0                   2
2        1/1      0             0                0                0                   3
VRRP ID  P/V      AUTHTYPE_ERR  PACKLEN_ERR   VERSION
3        3        0             0             2
2        1/1      0             0             3
Use the data in the following table to use the ip vrrp version command.
 Variable  |
 Value  |
 version  |
 Configures the VRRP version on the specified interface.  |
 <2–3>  |
 Specifies the version of VRRP (2 or 3) to be configured on the specified interface.  |
 vrf WORD<1–16>  |
 Specifies the name of the VRF.  |
 vrfids WORD<0–512>  |
 Specifies the ID of the VRF, and is an integer in the range of 0–512.  |
