A special CLI command mode provides a set of specific CLI commands that are different from the standard CLI command modes and the CLI commands available in them. For example, a set of CLI commands that are specifically introduced to configure services on a Virtual Machine (VM) through a specific CLI command mode.
Special CLI command modes are hardware dependent. If they do not display on your hardware, they are not supported or applicable.
The following table describes the special command mode.
                             Special command mode  |
                        Command mode navigation |
                             Command to access mode  |
                             Prompt displayed in mode  |
                             Description  |
                             Fabric IPsec Gateway  |
                        Accessible from Privileged EXEC |
                             virtual-service WORD<1-128> console Note:
                        Type CTRL+Y to exit the console.  |
                             FIGW>  |
                             Configure services like IPsec, fragmentation and reassembly, and to manage the Fabric IPsec Gateway VM.  |
                             IS-IS Router Remote Configuration  |
                             Accessible from Global Configuration  |
                             router isis remote  |
                        config-isis-remote> |
                             Configure the Multi-area SPB parameters like area virtual node, Shortest Path Bridging MAC (SPBM), manual area and so on.  |
