Enable channelization on a port to configure it to operate as four channels, or ports.
Important
Enabling or disabling channelization resets the port QoS configuration to default values.
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# interface gigabitethernet 2/1
Switch:1(config-if)# channelize enable
Enabling channelization on port 2/1. Subport 2/1/1 will inherit port 2/1 configuration. Subports 2,3,4 will use default config. QSFP will be reset as removal and re-insert.
    NOTE: Modify QOS configurations on all subports as required.
Do you wish to continue (y/n) ? y
            Display the port status:
Switch:1(config)# show interfaces gigabitEthernet channelize 2/2-2/4
                              Port Channelization
PORT         ADMIN MODE     CHANNEL TYPE
2/2          true           40G
2/3          false          40G
2/4          false          40G
            The following is an example of how to disable channelization on a port:
Switch:1> enable Switch:1# configure terminal Switch:1(config)# interface gigabitethernet 2/2/1 Switch:1(config-if)# no channelize enable
The following table defines parameters for the channelization command.
 Variable  |
 Value  |
 {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
