Viewing Statistics for a VRF
View VRF statistics to ensure the instance is performing as expected.
 - Click VRF.
 - Click the VRF tab.
 - Select a VRF.
 - Click the Stats button.
Stats Field Descriptions
Use the data in the following table to use the Stats tab.
 Name  |
 Description  |
 StatRouteEntries  |
 Specifies the number of routes for this VRF.  |
 StatFIBEntries  |
 Specifies the number of Forwarding Information Base (FIB) entries for this VRF.  |
